The smart solar controller within the EasySolar can have a low temperature charging cutoff set up (I have it set at +3 degC). The Multiplus charger-inverter within the unit does not appear to have the same function - or am I missing a trick?
I don't want to ruin the lithium batteries. The internal BMS is meant to shut off a charging current at 0 degC. The Smart Shunt connected to them was saying the battery temp was -1 degC, and the Multiplus was topping up the batteires.
