So i have 2 5kw 24v multis set in parallel, when setting the current limit on the charger tab in Ve config, should i set to the total for both inverters, or half? ie.. if i set it to 20A, is that 40A in total or 10A per inverter
This site is now in read-only archive mode. Please move all discussion, and create a new account at the new Victron Community site.
Settings in ve.config are for each device in parallel, so setting 20a in each unit means 40a total for 2 units. You must load ve.config for each unit.
31 People are following this question.
