The data sheet and manual for the smallBMS state that the charge disconnect output “becomes free floating in case of imminent cell over voltage or over temperature”. No mention is made of under temperature. Is it safe to assume this is an oversight in the data sheet and manual, and that the charge disconnect output does indeed activate upon under temperature, as well as over temperature?
