nir-fsight avatar image
nir-fsight asked
Set AcPowerSetpoint , MultiPlus using MQTT
I would like to set the value of AcPowerSetPoint using MQTT.
in the documentation, i see example of it using the following:
W/e0ff50a097c0/vebus/257/Hub4/L1/AcPowerSetpoint
However, I don't see any topic containing the "Hub4" nor I get any response for the command.
Is the Hub4 still valid?
Whet am I doing wrong?
thanks
Nir
MQTT
neo avatar image
neo answered ·
I think there is an error as the path should be in sync with the parameter of the topic you want to update.
I believe the correct path should be W/e0ff50a097c0/hub4/0/AcPowerSetpoint and not W/e0ff50a097c0/vebus/257/Hub4/L1/AcPowerSetpoint
