snowboarder005 avatar image
snowboarder005 asked
Blue Smart Charger
Hi I have the blue smart charger 12volt 20Amp version with 3 outputs, I have a AGM leisure battery connected to it and set the charger to AGM spiral, I would also like to connect my Van battery to the 2nd output but this is a Acid battery not AGM is this possible?
Thanks in advance
bluesmart ip22
kevgermany avatar image
kevgermany answered ·
Don't set the charger to spiral, not suitable for AGM. Use one of the Victron AGM settings.
You can connect to the van starter at the same time. Charging parameters are the same.
