Good day
I added an additional battery to my current system but now the total PV charger does not add up to the total loads plus the charging. (677+577=1254 missing 450 watt). Previously it did. Think the second battery is causing this. Did do a redetect on the battery but did not do anything. The battery is setup correctly with master and slave dip switches and correct network cable.
Any ideas what settings should be changed? The setup is as follow:
- Victron Multiplus II 48/5000
- Victron SmartSolar MPPT 250/100
- Victron Cerbo GX
- Around 5000 watt solar
- 2 x Dyness BX51100 5.12kwh battery
It seems like the charge and discharge is almost half due to the additional battery.
In the battery manual I only see the following:
When I go into the Cerbo settings I cannot change the MCC or the MDC and it shows the following. Is this causing the issue and if so how do I change these parameters?
