rkidwell1 avatar image
rkidwell1 asked
REC BMS, CerboGX, and DVCC - which solo at charge controller
I have a REC BMS connected to my CerboGX to control my MultiPlus II (with DVCC enabled). I am getting ready to add solar, but am unsure which MPPT to purchase. Can the 150/70 VE.Can TR MPPT has both VE.Can and VE.Direct, but I am unclear after reading the manual if can be controlled through the CerboGX DVCC. Can anyone clairfiy?
Thank you!
MPPT Controllers
Paul B avatar image
Paul B answered ·
using the ve direct or the ve can will work fine with dvcc
