I recently bought and installed 2 Multiplus 24/1600 inverters and an MK2 USB. I'm just trying to program them for parallel operation, but VE Config3 and VE.Bus Quick Configure won't let me into the inverter. VE Config3 says it detects the MK2, but then goes to a screen asking to select a coms port. The VE.Bus Quick Configure doesn't seem to detect the MK2. I'm using windows 10, which recognizes the MK2 as a device, and I'm pretty sure I managed to install the drivers correctly, after all VEConfig3 says the MK2 is detected. Please help.
