Hi all
i am looking to buy the Easysolar 48/5000 but first need to know if i can use it in the following manner ...
I will be using a 10kwh lithium battery with 12x 290w PV panels on the 48/5000 Easysolar panel ... i will like to use the solar power all the time up 2 the 5000W the panel can give but when the load is more ie. i use the stove then the extra load must come from the grid ... after the load is back to under 5000w then i am off the grid again and on solar again ...
Then when the grid goed down i will use the power form the 10Kwh battery sparingly till the grid comes back ... ( hope this makes sense )
Is this easysolar unit the correct unit for this or must i look at something ells
thank u for the help
Rgs,
Pieter
