kw4np avatar image
kw4np asked
Does the Quattro Transfer Switch Capacity Add in Parallel?
If two Quattros are connected in parallel, does the 100A transfer switch capacity add up to make 200A?
Paul B avatar image
Paul B answered ·
yes the total ac in is then 200 amps as each quattro takes 100 amps each
