When I try and charge my batteries with the charger it will only bulk charge for 2s then it goes into absorption. I have 3 x 100ah lifepo4 battery’s and my bms says there only 70% charged. The voltage is 13.5 at the charger and battery’s and the blue smart charger only puts in between 6 & 12 amps at 13.5v. Ive tried adjusting settings and even put it into power supply mode but it still only seems to put out 13.5 volts at around 10a. Why is not putting out 14.2 Volts at 30a? I’ve even got it link in with the smart network and tries removing it to see if it makes a difference. It doesn’t to matter what settings I change the charger still only puts out 13.5 at around 10a
