Hi , just done a upgrade from Venus os v 2.90~10 to v2.92~2 and backup my node-red and imported it , installed dashboard etc and got all the flows right .
But found when I was putting back the nodes which was disconnected , that in DC loads watts had been removed ? why .
O.K you have amps and volts so you can make your own , but I would have thought with the latest version parts would be expended not removed ?
