waninae39 avatar image
waninae39 asked
no ac input shown with mutiplus and cerbo gx
i added a new cerbo gx to the my mutiplus I system and new lion batteries.
the display show 80A of charging to the 4 Lion battery ( total 700AH)
but the display states no ac input available
the AC is coming in as the mutiplus is fully running and charging my batteries,
no-ac-avail.jpg why does the cerbo see the multiplus but can see any aC IN
MultiPlus Quattro Inverter Chargercerbo gx
Kienan avatar image
Kienan answered ·
Waninae,
Did you set up the AC Input in system setup? On the screen (or on the Remote Console), Click Menu > Settings > System Setup, then click on AC Input 1. The default is "Not Available" and you need to program it to either Grid, Generator, or Shore Power. The MultiPlus only has one AC input, so that should do it, but if that doesn't work, you could try playing around with AC Input 2.
Hopefully that works... let me know.
waninae39 answered ·
tnx. that method did work!
cheers
teddysx3 avatar image
teddysx3 answered ·
Worked for me also.
Cheers!!!
