My Multiplus 24/1200/25-16 does not have the correct grid code for my country, how can I add it to the Multiplus?
This site is now in read-only archive mode. Please move all discussion, and create a new account at the new Victron Community site.
In vrm app go to device list - > Remote VE Config and download the generated file and you can edit the configuration file using the VEConfigure 3. can be downloaded from the same page
I'm led to believe if the Unit is NOT shipped with the correct grid code for your country you can't change it, I have 3 Multiplus 1st gen and they all don't have the South African grid code. They were imported back in 2017 .
Hi @Alexandra , I understand codes will be updated with later firmware, but I have notice if the country doesn't appear on the Grid Code selection it will never appear. This is my unit after many firmware updates the South African code never appeared.
Is the ve config software up to date? That would also need to be the latest.
What country code are you looking for?
For most of the world that does not have strict legal/grid compliance requirements, the 'other non compliant' option is there.
You only really need the grid code for the ESS assistant, so if you do t intend on using that then you dont need to set the grid code at all.
63 People are following this question.
