I have 2 independent parallel ESS systems (each has it's own battery+MPII+venusGX) hooked on separate phase L1 and L2 of 3-phase power in the house. They both share the same smart-meter located at the input from the grid.
Both systems are connected via AC-in.
All works fine except that none of these systems sees each other.
Q: Is it possible to make them aware of each other so VRM dashboard will show 2 MPIIs with the energy flows so I don't need to switch from one dashboard to another to have an overall view?
I would expect something similar what I see when I configure Fronius inverter in PV-inverter section of remote console.
Thanks for advice.
