petemallorca avatar image
petemallorca asked
Cerbo Gx reading other brand batteries Bluetooth BMS
Can the Cerbo GX monitor the Bluetooth BMS connection for non Victron lifepo4 batteries? Not adjust any parameters, only monitor and make the details available on VRM. If not, why not?
gx device
bathnm avatar image
bathnm answered ·
The simple answer is no. I very much doubt it ever will.
Louis van der Walt avatar image
Louis van der Walt answered ·
Normally if a BMS has bluetooth, then it will also have a serial port for data.
Serial batteries can be supported. Many already are through my driver or a few stand alone drivers. So it will depend on which BMS your battery use.
See Victron VenusOS driver for serial battery BMS - LLT/JBD / Daly Smart / ANT / JKBMS / Heltec (VenusOS v2.80 compatible) - Victron Community
or https://github.com/Louisvdw/dbus-serialbattery
