joeccv avatar image
joeccv asked
BMV-712 starter battery wiring best practices
When wiring the BMV-712 in mobile installaitons, is it critical to run the cable all the way to the starter battery positive terminal?
In installations where the engine alternator is charging the house circuit, eg. via a DC-DC charger like the Orion-TR, would it be just as prudent to connect the aux. line of the monitor to the input of line of the Orion, Buck-Boost, or similar? How much would this affect voltage read-out?
Since some installations have the house bank and the BMV shunt quite far from the starter battery, it seems to make sense to monitor from the input side of the DC-DC, but I'm wondering if this is common practice or not.
BMV Battery Monitor
kevgermany avatar image
kevgermany answered ·
No reason not to do what you suggest. Voltage difference will be dependant on resistance between the 712 and the starter battery.
