Hello, I have one multiplus 48/3000 and I'm trying to disable the grid and go full on batteries when the grid is not needed, the grid will be enabled only when the load is above 1850W and I want to charge the battery during the night from 22:00 to 7:00. Unfortunately with the standard ESS I cannot get it work so I used the programmable relay, the general flag and the generator start/stop.
the multiplus correctly switch to the grid when the configured load is above the value, when the load return to normal values he switch off the grid. this part works properly.
But when I try to close the AUX1 relay (both manually and both using the Cerbo relay port) the multiplus did nothing.
Do you think my configuration is correct?
thanks in advance
