markusdahlberg avatar image
markusdahlberg asked
Problem with EasySolar 12/1600/70
I have a problem with an EasySolar 12/1600-70 system. Every time i flip the switch to "ON" the inverter trips to an overload alarm. Noting at all is connected and this happens all the time.
I have updated the SW via the vrm portal site and nothing helps.
The MPPT is working as it should.
I also have a Color control panel connected to the system.
Also the "charger only" function does not work. All the leds(RED , Yellow and Green) lit up and then it shuts down. After 18seconds that cycle repeats.
Does anyone have a clue on what to do?
Best regards
Markus
EasySolar All-in-One
Perhaps you could mention your battery type/model and battery voltages??
markusdahlberg avatar image markusdahlberg klim8skeptic ♦ commented ·
I have 2pcs of RITAR DC12-200 batteries in parallell and i have 12V at the moment in them.
The strane thin is that in my colorcontrol i can se when the inverter starts it only goes up to 56VAC and then shuts off.
Maybe a problem with the FET transistors?
Mike Dorsett avatar image
Mike Dorsett answered ·
Looks like the unit is faulty, should be returned for service / repair....
