Hello, I just arrived here today. Just a quick question about the setting on the Multiplus II GX. Basically, I will integrate it as an ESS in L1 to cover the supply with the battery via the netting utility meter. I have always seen in the instructions that the outputs should be switched off via config in ESS mode. My question now is whether the emergency power supply AC Out 1 can be used. I would like to connect the central heating there in order to keep it alive via the battery in an emergency. Management is not the issue here. It's just a matter of whether the AC OUT 1 is always in function or whether that bites with the ESS mode. Thank you
