permariusteigen avatar image
permariusteigen asked
Generator Node
screenshot-2022-09-18-093438.pngge.jpgHi
This is in Autostart mode.
When I set up a node to find out why gen starts (Condition that startet the gen), I only get to report the number 1, manual.
Does anyone else use this for something, get a different status?
In the picture it started on SOC but it does not come up.
update:I see it at first, but then it disappears very quickly.
update2: Since it is in manual, it looks like it does not stop as it should
(the tank gauge is not connected yet)
With best regards
Per-Marius
https://vrm.victronenergy.com/installation/18889/share/90968aa1
GeneratorNode-REDgenerator auto start
permariusteigen answered ·
I may have found the problem with the help of some tips on Facebook. Node-Red which sneaks in a signal as a mauel when relay 1 is switched on. Will try with the next opportunity, then I will update so others don't end up in the same situation. :)
