Hello, I understand this is an odd question, as this is what the purpose of the float function is. However I would like to use solar system to simply charge my boat battery when it gets low and then " physically turn off" the solar panel and solar controller after. Why ? I need to charge my battery once every three months and do not want to worry about something going wrong with system. Is this unheard of , or is there a way to do so ? I thought of putting a switch between the panel and controller, but not sure.
Controler : Victron 75/15MPPT
Solar Panel : 50 W
Battery : 79Ah AGM
