Good day All
My setup as follows:
Victron Multiplus 48|5000|70
MPPT 150|35
SunnyBoy1.5 ( On AC Out L1 of Multi )
Newly installed:
Venus GX
2x 48V 100Ah enerSol LiFeP04 With CANBUS BMS
I used to have LA batteries and used the following assistants:
General Flag for AC Ignore
Generator assistant
Self consumption Hub V2 / 3
The setup ONLY went to grid when batteries were "flat" so to speak.
All worked well until now....
After installing the new batteries and VGX I had to change things up a bit.
Because the Self Consumption V2 / 3 Assistant DOES NOT have an option for CANBUS
LiFeP04 batteries I can no longer use it.
The Problem:..............................
How do I set my inverter to frequency shift to control the SunnyBoy's output if my battries are full? I can't connect it to the grid side of the inverter as we have a prepaid meter which deducts kWh if I feed into the grid.....
I found this section under VS options The part with the rectangle around it, I thought this might be for frequency shifting but am not sure as I can't find much documentation on the VS option.
Any advice welcome.
Regards
Charles
