Is there an easy way to completely reset your whole node red installation on a cerbo? I tried to change between normal and large images but (as expected) some of the node red settings files etc remained. Should I just delete the .node-red directory? Is there more that I can delete to make sure the installation is completely set back to standard when I do a large/normal switch.
