Once I have my PV system up and running, the ultimate goal is to be independant from the grid, i do have a fairly large daily consumption, but one of the largest power consuming, single items is my 410 amp single phase 240v welder. This runs quite happily from the mains on a 40amp breaker, so would estimate its maxiumum power consumption to be approx 10kw. My question is will the 15kw Quattro inverter be happy running this with 100% battery/solar input or would it require assistance from the grid, or would it help the situation to run 100% from battery/solar if I had 2 x 15kw Quattro's?
