Perhaps I should clarify that this is just a bit of information about my system for reference:
I'm trying to use a Smart Shunt to measure my DC system which has both loads and chargers (solar). There are three Quattros connected directly to the batteries that measure their own usage and report it via VE.Bus to a Cerbo GX. The Smart Shunt is also connected to the Cerbo GX, and the Cerbo GX should be able to keep track of total SOC by using the data from the Smart Shunt (in DC System mode) and Quattros. The manual seems to indicate that all other modes just display the data. https://www.victronenergy.com/media/pg/CCGX/en/installation.html#UUID-d0c1e103-df9e-4691-b369-33d047b01491
This is the question that's also in the title:
With the Smart Shunt in DC System mode, the current flow from the solar charger is displayed as a negative value. Switching to a different mode in the SmartShunt menu, such as Solar Charger, causes the current to be displayed properly as a positive value. The Shunt is installed properly with loads and chargers (excepting Quattros, which track their own usage) on the System terminal, so that should not be the issue.
Any ideas on why the DC System mode shows a negative value for current entering the batteries?
