Hello! First time posting here!
I have a SmartSolar 100/50 Charge Controller and three arrays of 3 x 100W panels in series-parallel for a total of 900W of solar.
I just installed the SmartSolar and the third array and it was working okay - was getting about 475W maximum on the roof of my camper. I was hoping for more, but it is almost September in Connecticut. Was permanently installing the third array and now the controller is stuck at about 60W of solar going into the batteries. That seems to be the output of one panel.
I have tested each array and getting 60V from each, so the arrays are working.
If I plug one array into the controller, I'm getting about 180-200W, then drops to 60W. I've done that for each array separately.
All three arrays connected I'm still at about 60W.
I've changed connectors, splitters, everything, and still only getting 60W.
Is there some sort of issue with the charge controller that's limiting the input into the batteries?
Thank you!
Chris
