I am getting a solar/battery setup based around the Quattro 10000. I was wondering why there are two DC connections. Is it to give more flexibility for wiring with smaller wires?
I am planning on running for sustained periods at 200A on the 48V side. At the moment this is using a single 95mm wire under 1.5m long. I am presuming it doesn't affect the Quattro only using a single connection point with the maximum current?
Thanks
