After installing ESS my Multiplus II stay in passthru mode AND the SmartSolar MPTT , connected via VEcan, stop charging battery!!
For force the charging i have to disconnect VEcan cable to the SmartSolar mptt .
All the configuration of ESS are the default.. the Battery system tab in ESS configuration is:
"System use LifePo4 with other type BMS and are protected from signal Hi/Low voltage by external cable.
I use SBMS120 as BMS, .. this BMS has 2 different contact .. one is for prevent over discharging ( connected to the remote on/off cable of Multiplus).
The second is for prevent overcharging and is connected to remote control input of my MPTT SmartSolar VEcan.
Thans in advance,
Fabrizio.
