Hi! I’ve connected a Multiplus compact 12/1600/70 to a lifepo4 310Ah. Everything works well, except the grid charging. I only have been able to charge for test the first time I connected the Multiplus. Since then, nothing more from grid. The inverter works, the priority circuit works. But no charging. Appears directly a floating status and no amps to the battery. Anyone has ideas? Thanks!
