Hi all,
Looking to get some feedback on the design below. Looking to incorporate a DIY battery solution at home with my current PV inverter (GoodWe 10KW). Looking to use the Victron MultiPlus-II 10000 for the 1:1 ratio but wanted to understand if it'll work well with the GoodWe Inverter and the JBD BMS. Are there any suggestions/change you'd recommend?
Thanks for your time!
Some other tidbits that might help:
- I'm based in Australia.
- GoodWe inverter and panels are installed.
- I have the LiFePO4 cells on their way.
- Would want solar to supply loads first and then the remainder to charge the battery
