nam-erik avatar image
nam-erik asked
Node Red Dashboard install
I have installed Venus OS Large 2.90~21 (Einstein), under the VRM menu OS Large there is only the Node Red link but not node red Dashboard. How do I get the dashboard link?
Thanks,
Node-RED
Mark avatar image
Mark answered ·
You need to open the normal Node-RED editor and then download the dashboard node set from the Palette manager.
https://www.victronenergy.com/live/venus-os:large#node-red_dashboard
https://nodered.org/docs/user-guide/runtime/adding-nodes
https://flows.nodered.org/node/node-red-dashboard
Once installed the remote link via VRM will also become available.
iammotorhomeless avatar image
iammotorhomeless answered ·
You most likely still need to install the node-red-dashboard
it is not there by default !
Correct, it really should be bundled imo.
Dirk-Jan Faber (Victron Energy) avatar image Dirk-Jan Faber (Victron Energy) ♦♦ nickdb ♦♦ commented ·
That has to do with the inability to upgrade to the latest version for the end-user. If we ship it with the large image, it ends up on the root partition (which is read-only). If the user installs it manually, it is upgradable to the latest version.
Norman Kühn avatar image
Norman Kühn answered ·
Hallo Zusammen,
vielleicht kann mir einer helfen?
Bei mir gibt es den 'palette manager nicht als Menüpunkt.
Umgebung:
Cerbo GX
Large OS
Firmware 3.30-18
Node Red v3.1.5
Danke, Gruß Norman
