Hi, in a system with various devices (inverter, charge controller, BMV etc.) connected to a CERBO, what data is available to 3rd parties via the VE.Direct interface?
Is data from each device available?
If data from each device is available then when various devices provide the same data (for example battery voltage) is the voltage parameter determined by the CERBO?
