I have emailed DC Power twice and called them twice to no avail so please can someone help me understand how to translate the spec sheet for my battery into the correct settings for the Victron Blue Smart IP22 Charger.
The battery is a DC Power DCM-120-XFR (which is an AGM battery with a 120Ah (C100) capacity).
The spec sheet is linked to at:
https://cdn.shopify.com/s/files/1/0084/9369/5035/files/DCM-120-XFR.pdf?v=1637682971
I have attempted to translate the details but unsure of a few things so was wondering if the following is correct or not:
Absorption 14.4V
Float 13.65V
Storage 13.65V
Ideally I want the most optimal charge profile so that the batteries fully charge, while optimising their lifespan.
There are a few things I don't understand on the spec sheet, such as what CCA is, "cycle service" too, is this when the battery needs serving as I've never heard of AGM batteries needing to be serviced.
Are there any other settings I need to be aware of or should probably change in order to configure the charging to be the most optimal it can be?
Thanks for any help you can give :)
