Hi Community / Team / Support,
was checking "Charge a power station directly with smartsolar? " but that did not answer my question. I have a solar panel connecte to the MPPT 75/10 which directly loads the (secondary) battery of my CamperVan. Can I connect a Powerstation (which accepts 12V minimal voltage to load) to the consumer connection?
Will give it a try anyhow - but before I buy/assemble the required cables - any idea
a) does it work at all?
b) which is the preferred consumer (assume direct consumer comes first - then the battery)?
Thanks for any hint
BR Ingo
P.S. just figured out there is a German subsection - lets be international here
