mio23 avatar image
mio23 asked
Quatro 15kW or 3 x Quatro 5kW?
Hello. I have a dilemma. My house receives 3 phase electricity from the supplier. I want to replace this electricity with my own solar energy as master energy. Please, can someone tell me if it is good to have 3 x quatro 5kW or one powerful quatro 15kW. I'm afraid that 3 quatros won't be as noisy as one quatro. But won't one quatro 15kW have a big loss or consumption for itself like 3 quatros? In the house, I would probably merge 3 phases into one via a contactor. If the quatro falls out, it divides the phases back into 3 phases. Is this a stupid solution?
MultiPlus Quattro Inverter Charger3 phasesplit phase
kevgermany avatar image
kevgermany answered ·
You need one per phase
Gerardo avatar image
Gerardo answered ·
Hi Mio,
If you are planning to have a 3-phase output in your solar system, you need 3 x Quattros, one per phase. End of discussion.
If all the appliances in your house are single-phase, then you can consider different options: 3 x 5KVA in parallel, or just 1 x 15KVA.
My recommendation:
- If your system is budget-sensitive, go with the 15KVA. It is cheaper than 3 x 5KVA, more efficient (less losses at low power) and easier to commission.
- If budget is not an issue, and you want some versatility in your system, go with 3 x 5KVA. That system will allow you to split the phases in 3 if required in the future. Also, you could remove 1 or 2 units from your system and use them in another installation for example.
Regards,
1*15KVA means a potentially dangerous, non compliant rewire and switching. It is not a good idea.
