I am in the learning phase
I have set the values in a fake file in Ve.config but have some doubts in the charger tab. Where you can choose that the charger should stop charging after the bulk stage, you can click in it and still select all four values in the Ignore AC input tab?
I want shore power when the battery is too low and / or load too high and ignore when the load is normal again and / or the battery has reached ca 54V or end of bulk.
It does not really appear in the PDF file in my opinion.
virtual-switch-ignore-ac-lesson (1).pdf
If something looks very wrong, I am grateful for help.
