dancrompton avatar image
dancrompton asked
Smart Solar MPPT 250/100 is being very close to but just under 250V possible?
Hi, I was hoping someone could tell me whether the 6S4P OR 6S3P configurations will work with the SmartSolar MPPT 250/100.
My panel spec is as below. In both configurations I make it 249.72V/45.88A and 249.72V/34.41A respectively. I know 249.72 is awfully close to the limit, but it is still below it. Yet the Victron MPPT calculator does not include it as an option when I enter my details? In fact it provides no options when I add more than 5 panels in a series. Am I missing something (Won't be the first time)?
I have a 50 metre cable run hence the need to get the voltage as high as possible.
Make: JA Solar
Wats: 380W
Model: JAM60S20 -380/MR/1000V
VOC: 41.62
LSC: 11.47
https://www.jasolar.com//uploadfile/2020/1013/20201013031958494.pdf
Thanks.
MPPT Controllers
That will not work. Due to the temperature coefficient the Voc will rise at temperatures below 25°C. In winter that can easily be 10% more voltage.
You have to go with max 5 in series.
seb71 avatar image
seb71 answered ·
If you did not already bougth anything, look at RS MPPT. That has a higher PV voltage (read the manual for details). But it has some limitations (such as slightly lower maximum battery voltage - this might or might not affect you).
