bigalmacmac avatar image
bigalmacmac asked
BMV-712 No bluetooth connection after two days
Brand new install. Delighted worked the first time. Bluetooth connection to app worked well, went through several automatic firmware updates. All good. Functionality tested in app. All good.
Two days later nothing...
App cant find the device. Tried on Apple and also on Android. No bluetooth from Smartshunt.
Checked fuse all fine
Depowered shunt (physically removed battery connections)
Tried again. Nothing.
Seems to me the bluetooth module on the Shunt has died. Any other suggestions.
BMV Battery Monitor
seb71 avatar image
seb71 answered ·
Is it a SmartShunt or a BMV-712?
The Bluetooth can be disabled from the settings. Could be that. But obviously you can't use Bluetooth to enable it back.
Also in the phone remove the Bluetooth paired device and try again.
