I have two MPPTs, a 150/60 and a 100/30 connected to a 700w bank and a 300w bank. Both MPPTs connect to the house bank via common bus bars . Both MPPTs have identical setups. VictronConnect shows 36A output at 14.4v in absorption for the larger PV bank. No output is shown for the smaller bank which shows float at 14.26v not the 13.2v as set. Voltage readings have been confirmed at the MPPTs as well as current. Cabling from MPPTs to busbars is 6 gauge so voltage drop is minimal.
Ideas on what is the issue is?
