VRM control buttons are back
And with a safety construction now ;-)
Thanks VictronTeam
This site is now in read-only archive mode. Please move all discussion, and create a new account at the new Victron Community site.
Thanks VictronTeam
Not an answer but a question: Is it still the case that having a DMC on VE.Bus disables control from VRM or Remote Console? That's what I'm seeing with my system.
Hi, @dunnp : if you have a Digital Multi Control (DMC), which has a hard toggle switch, you cannot change it between Off, On and Charger-only in any other way than physically toggling that switch on your DMC.
We will not change or fix that in a software update. The only solution, if you want remote control, is to remove the DMC from the system. Warning: in case you also have a VE.Bus BMS, then removing the DMC won't help, see GX manual for exact limitations when having a VE.Bus BMS. We are coming with a newer VE.Bus BMS which fixes that limitation. But there is no release date for that yet; and its a new product: there is no software fix coming for the on/off/charger-only limitation related to todays VE.Bus BMS.
The new controls are still a nice addition, and well thought out precautions to guard against accidental shutdowns. Well done.
Cheers
Phil
How to change the Owner of a VRM installation
40 People are following this question.
