Hi.
I’m considering adding Gobius external sensors to my black water holding tanks. These work from outside the tank, using active signaling for short bursts of measurement, indicating 1/4, 1/2 or 3/4 filling level (one sensor for each) when a button is pressed. The unit can then output a standardized resistance measurement - and they publish a guide for connecting this to the Cerbo GX.
My worry is that since the measurements are done in short active bursts, the tank-level might simply return to zero after the active measurement period - or when the unit is turned off. This would make connecting to the GX of limited value. If on the other hand - the GX can be set to remember the “last active measurement” then the system would work perfectly!
So how does the Venus OS deal with resistive tank sensors that come and go?
Or does anyone have any experience with the Gobius or other similar sensors?
