Hi all,
UK resellers not too helpful....hence asking question here. I'm running 2x150w mono flexi panels on my RV in parallel connected to 3x100amp AGM batteries.
the spec of the panels are:
Max Power Voltage per panel - 18.15v
Max Power Current - 8.26amps
Open Circuit Voltage - 21.45v
Max System Voltage - 100v
Short Ciruit Current - 8.68amps
Would I be correct in saying that the 100/20 would suit at a squeeze (300watt panels / 14.2v) = 21amps? Or I could go 100/30 should I want to increase PV panels?
I have a bonus question:-)
I'm currently running a cheap vechline PV controller with these specs:
I'm guessing the Vechline is bottlenecking the whole system?
Your help is much appreciated.
