I have a system with a Cerbo GX, Quattro and AES Discover battery with the Discover Lynk communication device to the Cerbo GX. I also have two MPPTs charging the battery. All components are connected to the Cerbo GX.
The issue I'm having (as far as I can tell) is that when the battery reaches a low state of charge and the inverter shuts down, it enters a fault state and won't turn back on after the battery is charged. What I would like to happen is that the system automatically turns back on when the battery regains a charge.
I can turn the system back on by going into the Cerbo GX menu for the Quattro, then selecting 'advanced' and then 'system reset'. The inverter then starts up and inverts.
The only thing I could find in the menus to 'resolve' the issue is to disable the low battery alarm, which I've done. I don't know if this will have the desired effect? Is there a better way to configure the system?
