Setup:
ESS Assistant (Europe)
Multiplus II 24/3000/70, Cerbo GX, MPPT 100/50, SmartShunt, LifePO4 210Ah 24V batteries
Feeding to Grid is not allowed
My idea was to install a automatic switch on the Multiplus input to switch between the grid and generator in case of grid failure.
The issue is that Multiplus gets an error
Error 11: Relay test fault on VE.Bus System when generator is connected to the input
Any Idea how to solve this issue?
