randallemarshall avatar image
randallemarshall asked
Smartshunt state of charge, consumed ah, and time remaining all say "--"
I put together my system over the last few days. It has a Multiplus 2, SmartSolar MPPT, Cerbo GX, Smartshunt, and a 48v LiFePO4 battery. This evening I noticed the Smartshunt state of charge, consumed ah, and time remaining all say "--." This afternoon it was at 100% before I left for a few hours. My PV was supplying more power than I am using.
What would cause the Smartshunt to lose the measurement? I can sync at 100% again tomorrow when the sun is out. I did change some charge settings this afternoon but that was before sundown. Any thoughts? Thank you.
SmartShunt
kevgermany avatar image
kevgermany answered ·
What settings did you change? These are all values that can only be calculated once the shunt knows it has a full battery. Chances are it will show these values automatically after it recognises the battery is full. If you manually synch to 100%, the values will be reported, but won't be correct.
Maybe post a screen shot of your settings.
randallemarshall avatar image randallemarshall commented ·
I believe it was tail current and efficiency factor but there may have been more. I will wait until the charger goes into float mode before syncing to 100%.
randallemarshall answered ·
I waited until my battery read 100% state of charge and the solar charge controller was on float mode. Unfortunately the shunt did not update with the state of charge. I synchronized it to 100% and I'll watch it to see if the data disappears again.
