I currently have a couple of Maxxair roof fans installed and am looking for a way to activate these via the Cerbo GX once a certain temperature is reached and then switch off again when temperature reduces to a lower temp - I can see from previous posts that the programming of this can be done within the Cerbo GX linked to a Ruuvitag sensor.
I'm getting a bit lost on how I introduce the Cerbo GX into my existing fan wiring setup which i currently 2 fans wired in series to a fused (10a) 12v circuit.
Any advice would be greatly appreciated.
