Hi! I had someone install my Venus GX in my truck camper. They did not save the box and installed the Venus GX in an inconvenient location (I can only see the top and one side). Is the VRM Portal ID located on the bottom of the unit or one of the sides of the Venus GX? If the VRM Portal ID is on the bottom of the unit, I’ll need to remove it (bad). If it’s on the side I may be able to see it with a mirror.
BTW: I am seeing the WIFI login information/network for the Venus GX if that helps.
Thanks!!
