In Excel Calculator version 4.0, the voltage (volts) and the current (amperes) are added together.
Either I am completely wrong or a small calculation error has crept in.
Easy to try out. Simply select a panel, increase the number from 1 to 2, the voltage should double and the amperage should remain constant. Unfortunately, the amperage doubles here as well.
Is that correct?
