I only need % charge info to know when to charge my 2-6 volt acid batteries in series with my generator and when to turn off the generator when batteries are at 100%. I believe that I have the SmartShunt connected correctly for Bluetooth except for the 2 small red wires. Do I need to connect one small red wire from each battery’s + terminal to the SmartShunt or is only one small red wire necessary since the batteries are in series? I don’t understand if I need to set it up for the “midpoint” with 2 red wire connections or not.
